Pinging Oliver
DRG
04-24-2004 13:51:40
Have a 1800 Oliver diesel which when pulling hard pings like a high compression gas engine on regular gas. Have done a valve job and an injector job(which was needed) and had hopes that it would take care of the problem. Could it be timing? Or is it a weak injector pump? Am afraid it is the later.
J.
04-24-2004 17:29:32
 Re: Pinging Oliver in reply to DRG, 04-24-2004 13:51:40
First of all, which 1800 do you have? There was the 1800 A series with a 283 engine and the 1800 B & C series. Reason I asked the B & C series had an advance mechanism on the injection pump, the A series did not. Next thing have you checked the timing? The timing specs for the three models are also different. I do not understand your term a weak pump. To me that would indicate a worn pump head and it is worn to the point the engine does not start and since it runs that is not the case.
How comfortable are you working on a diesel engine ?
DRG
04-24-2004 20:26:49
 Re: Re: Pinging Oliver in reply to J., 04-24-2004 17:29:32
According to serial no. the 1800 should be an A and I am pretty sure the engine is a 283. It does start well cold and warm. The Oliver-White dealerships are gone from this area. I am working with a mechanic who is good on the other green, but lacks the experience and specs of Oliver. I don't do diesel repair. I will pass on any helpful info to my mechanic. He has researched what was needed to do the valve job and think he could do other adjustments that do not require special tools. Do appreciate any suggestions.
J.
04-25-2004 07:51:22
 Re: Re: Re: Pinging Oliver in reply to DRG, 04-24-2004 20:26:49
It is has the original pump-no advance added, then timing is 8 degrees before TDC.
DRG
04-25-2004 18:18:24
 Re: Re: Re: Re: Pinging Oliver in reply to J., 04-25-2004 07:51:22
Thanks, will give that a try.
