SOT Save our tractor
Phil
04-24-2004 12:25:45
I need help.. im only a novic at this stuff and im only 16.. I have a 77 rowcrop gas. what is the fireing order, the points gap and is it alsp possible to put a 550/55 carb on it?.. Thanks
Phil
J.
04-24-2004 17:33:06
 Re: SOT Save our tractor in reply to Phil, 04-24-2004 12:25:45
Firing order 1-5-3-6-2-4. Point gap 16-18 will work well. Carburetor, the answer is no or yes. There are two different venturi sizes used on the 550 and the Super 55 is the same as the early 550. What is the problem with your carburetor. Are you thinking about pulling?
Phil
04-24-2004 18:20:34
 Re: Re: SOT Save our tractor in reply to J., 04-24-2004 17:33:06
yes. im thinking about pulling... theres also a chunk missing out of the top of the carb
Thanks
Phil
04-24-2004 18:21:41
 Re: Re: Re: SOT Save our tractor in reply to Phil, 04-24-2004 18:20:34
will a bigger carb help?
