Thirsty Oliver 77
Warren
06-11-1999 09:35:35
I have an Oliver 77 RC gas tractor that starts easily, runs smoothly, and seems to have plenty of power. The problem is that it uses a lot of gas. The tractor does not smoke and the governor seems to kick in at the appropriate time (sometimes a little too much). I have noticed a strong raw gas smell when using the tractor especially at idle speed (maybe because the wind isn't blowing as strong). I have checked for gas leaks at the carburetor, gas lines, sediment bulb and tank and they are all dry. Any ideas on this problem?
Pete in Ks.
06-14-1999 05:00:55
 Re: Thirsty Oliver 77 in reply to Warren, 06-11-1999 09:35:35
Check your air cleaner. If it is dirty it will really suck fuel.
Bob
06-12-1999 19:27:03
I have a couple thirsty Olivers myself...an OC-6
and a 77. It costs alot to run around with perhaps
the finest sounding 6 cyl ever put in a tractor, and you will never be confused with one of those
hideous John Deeres. As for the gas smell,my
tractor stinks a bit to, but I know its just
from having a loose fitting gas cap directly in front of me, and the smell just waffts back. Try
putting a wet rag over gas cap while your putting around, and see if the smell abates.
