Need 1650 Brake Help
Tim
04-20-2004 17:34:07
I attempted replaced the brake linings on my 1650 this weekend. However, the outside cover wouldn't tighten down. I slipped a used disk on the outside and the cover tightened. But, that braked locked tight. I called my local dealer's parts man and asked about the shims behind the housing. He said leave them alone and add shims to the outside cover?? I said there aren't any? He there should be and most likely were thrown away over the years. But, my parts book shows only the inside shims. Who is right? I put washers under the cover per his suggestion. Anybody have any others?
Bob
04-21-2004 08:30:56
 Re: Need 1650 Brake Help in reply to Tim, 04-20-2004 17:34:07
Make sure your brake ajustment is backed off all the way if you are installing new linings
Myron KY
04-21-2004 05:32:44
I had the same problem on my 1850. The other fellas are right. You need brake cover shims. This one is off an 1850. The 1650 shims should be similar.
third party image
I had one shim and AGCO wanted to sell me new ones at $18 a piece. I bought $6 worth of sheet metal scraps and made, several, of my own using my one shim as a template.
HTH and good luck!
Myron KY
Wes Dorhout
04-20-2004 18:20:35
The inside shims are to adjust the ring and pinion LEAVE IT ALONE as the parts man said. I have used outside shims. E-mail me or call 712-324-2760
J. Schwiebert
04-20-2004 18:18:12
Depending on what parts book you have it may not show the outside shims. That was a "field fix" and a good one. It give you better and more brake action. The inside shims adjust back lash and bearing cleanaces. Leave them alone!
