Tight plug update and the next dumb question
Pete
04-20-2004 16:45:03
I took the tractor over to my neighbor and he heated the casting around the plugs with his torch. I was able to break the one free but the second one wouldn't budge. I ended up taking it home and slipping a 3/4 inch nut over the narrow end of a 3/8 socket extention. Then I welded the extention into the square slot of the plug and then welded the nut to the extention as close a I could to the plug. I was able to break the plug loose by putting a wrench on the nut and a breaker bar on the extention.
The next dumb question has to do with me taking the restrictor valve assembly to replace the O ring that was damaged by the heat. Of course the valve plunger fell down the into the housing oil passage, just as the service manual warned me not to allow to happen. I should have read that first but who has time during the heat of battle. Anyway, I am wondering what is going to happen now that it is down there and where will it end up? Is it likely to end up somewhere it could break something? What will be affected by the plunger being out of it?
Thanks for any help
Pete
J. Schwiebert
04-20-2004 18:23:48
 Re: Tight plug update and the next dumb question in reply to Pete, 04-20-2004 16:45:03
My next dumb questionis for you send me an e-mail address either through here or through the Olivergang or the oliver hartparr web site.
Pete
04-20-2004 19:17:16
 Re: Re: Tight plug update and the next dumb questi in reply to J. Schwiebert, 04-20-2004 18:23:48
My e-mail is [email protected]
J. Schwiebert
04-20-2004 16:57:23
O. K. I never dropped one, but that passage has to line up with the port where the hose comes out of the unit. Undo the hose and stick a magnet in there and see if you can catch it. It not take the seat and the top off , no big deal to do that. The restrictor is a flow control use to regulat the speed of drop if it is hooked up correctly.
Pete
04-21-2004 13:00:43
 Re: Re: Tight plug update and the next dumb questi in reply to J. Schwiebert, 04-20-2004 16:57:23
You were right on the money. I had to take the top off to get it but the plunger was laying right in the bottom of that port. I got her all put back together and everything seems to be working fine. I should be all ready to put the bucket on and see how this loader works.
Thanks
Pete
