88 Clutch Shaft/PTO Hub Questions--Need Help with
K. Kilian
04-20-2004 06:38:10
I'm getting ready to convert my 88 RC from the older PTO hub that used a bushing to the newer version that used a ball bearing. According to my parts book, a different clutch shaft was used with the ball bearing hub. My questions are:
1. What measurements (shaft length, diameter, etc.) can I use to ID the correct clutch shaft? The parts place I found has several shafts but can't help with ID.
2. Will a clutch shaft from a 77 RC work? I thought they might, but have heard that the 77 is shorter.
3. Are ball-bearing PTO Hubs fairly interchangeable? I have found several that appear similar to the picture in the parts book, but would like to make sure.
Sorry for the length...thanks for the help!
jld
04-21-2004 06:09:06
 Re: 88 Clutch Shaft/PTO Hub Questions--Need Help w in reply to K. Kilian, 04-20-2004 06:38:10
Can't answer your questions as you asked them, but my brg hub and shaft was bought as one part from an Agco dlr about 2 yr ago. Part # 30-3068277 was about $205. I think someone still makes this because the parts looked very fresh. An Agco dlr might come up with just the shaft if you asked for K-579A. If not Agco, then possibly O'Briens or Maibach Tractor. As I recall, the shaft is different size for the brg ID vs the bushing ID.
