88 rear end became locke up
Jon
04-20-2004 04:18:15
Shortly after I pulled the 6500 on my s88 I was leaveing the track to run across the scales I went to turn and it just shoved the front end. I made it across the scales eventually. Then loosened up both the brakes. Still wasnt fixed. So I was driving it a little to see if anything happened. I heard a couple pops in the rearend and then it was fine for a minute then it locked up again. It does this continuely. What has happened? Any info would be appreciated!
Ollie Puller 2
04-25-2004 10:40:03
 Re: 88 rear end became locke up in reply to Jon, 04-20-2004 04:18:15
I had a similar problem and discovered that one of the Bull gears had broken the welds. Rewelded both gears and no more problems.
Marty
04-22-2004 11:48:24
Jon,
Sorry to hear about your misfortune. Hard to diagnose without tearing into it. If you find that things are trashed, I have a nice tranny rearend and rear case out of a Super 88. No axles or axle housings. Everything else is there. Let me know if I can help.
