Rear Axle Seal on a 55 Super Oliver (Gas)
Barney Mitchell
06-10-1999 21:02:00
Does anyone out there know if I have to remove the top plate of the transmission to remove the
rear axles on a 55 Super? I am experiencing a
rather serious leak in the right rear axle. Thanks for any help that I might recieve.
Chris
06-10-1999 21:11:13
 Re: Rear Axle Seal on a 55 Super Oliver (Gas) in reply to Barney Mitchell, 06-10-1999 21:02:00
Yes. The 3 point hitch/tranny cover has to come off so you can take the snap ring off the axle to let it slide out of the bull gear. If the seal is the only problem, you can change that without pulling the axle. All you need to take off is the wheel and the hub. This needs to be done no matter what in order to change the seal and/or the outer bearing. Hope this helps.
