need help....rod bearing on 77!!!!
John
04-19-2004 14:12:52
Put a new crank in my 77. It is a 1953. The #3 journal is being a bi.. ! the crank journal measures 1.895 or 10 under..... When I torque the #3 rod the crank won't spin....It's too tight. I miked the rod torqued with the bearing in and it measures 1.855 ( or so)???? What the heck is going on??? Can I shim this rod or do I have bigger problems....This is the same rod that has 5000 hours on it like the rest of the tractor....Any advice is appreciated....Thanks...John.
Larry from MD
04-20-2004 04:58:42
 Re: need help....rod bearing on 77!!!! in reply to John, 04-19-2004 14:12:52
Make sure the numbers on the cap and rod match!!Don't use shims.
J. Schwiebert
04-19-2004 16:55:05
If you just put the crank in, you probably did not take the head off. I would take the rods and have them reconditioned because they get out of round and then they do not provide the clearance all the way around. Also if the 77 is pretty well original I would definately go with new pin bushings. Questions?
John
04-19-2004 17:29:34
 Re: Re: need help....rod bearing on 77!!!! in reply to J. Schwiebert, 04-19-2004 16:55:05
believe it or not, I took the rod in question OUT FROM THE BOTTOM! Don't ask.... I think I'm going to take them all out (from the top....Just put a new head gasket on also....). and have them done... Should I just use the specs from my IT service book??? also, When I put these back in, I don't have to play with shims, do I??? That's just on the earlier ones....Correct??? Also, I cracked my oil pump. Got one of those handy??? Thanks for your help....John.
J. Schwiebert
04-19-2004 18:25:51
 Re: Re: Re: need help....rod bearing on 77!!!! in reply to John, 04-19-2004 17:29:34
The bore size for the rod big end will be in your machinest bearing book, either F-M or Clevite. Tollerance is normally 1/2 thousands.
John
04-20-2004 17:49:24
 Re: Re: Re: Re: need help....rod bearing on 77!!!! in reply to J. Schwiebert, 04-19-2004 18:25:51
Thanks..... ...
Wes Dorhout
04-19-2004 18:18:08
I have used oil pump. 40.00 plus shipping
