Just got an oliver 770??
steve
06-10-1999 03:15:02
i dont see much talk about a 770. im not a collector, bought it to work. it aint pretty but it seems to run fairly well, supposedly only 20 hrs or so on a rebuilt engine, that was in the last 15yrs, i went thru most of the fluids and filters, anything else i should go over and check before putting to work? any idea on a price, its a 66, diesal, industrial, with a backhoe
Adam
06-10-1999 20:40:39
 Re: just got an oliver 770?? in reply to steve, 06-10-1999 03:15:02
If you got the engine, air cleaner, drive train and hydrolics checked out you should be in good shape. Only advice I can give is to make sure there is no water in the rear end drive case I have found quite a few that had water in them especially ones that sat around alot. I have a 1960 770 diesel that I use verry hard it has done ok. Good luck.
steve
06-11-1999 02:41:31
 Re: Re: just got an oliver 770?? in reply to Adam , 06-10-1999 20:40:39
yea the rear end had alot of water, i pulled the fill level plug and it looked like mayo. i am startin to have fluid leeaks, looks mainly motor oil, think one of the leak stop products would be of help?
