Just smilin...
Don-WI
04-16-2004 22:46:28
I FINALLY had a chance to work our new 1855. Put the duals on, hooked to our 20ft. spring-tooth, and worked a couple acres with it. Running in 4th Over vs. 3rd low on the 285 massey is a MAJOR difference. Ours is a late model, built in oil cooler w/ sock type filter. Changed engine & over/under fluid when we bought it. Might still get a hyd. filter and atleast change the filter, probly do the gear lube as well. That tractor's gonna toy with our 3-16 plow. It sure feels great being able to run a bigger Ollie for a change, without having to worry about the engine so bad.
Donovan from Wisconsin
Myron KY
04-19-2004 18:02:23
 Re: Just smilin... in reply to Don-WI, 04-16-2004 22:46:28
That's great Don! Glad the 1855 is working out for ya.
Myron KY
