What is the difference
farmallman
04-16-2004 13:19:49
What is the differenct between a row-crop and a standard. My Cockshutt 70 has a narrow front so is that standard or row-crop. Thanks
Dsl
04-16-2004 14:02:55
 Re: What is the difference in reply to farmallman, 04-16-2004 13:19:49
Your tractor is a row crop.
Row crop tractors are defined by the ability to adjust their tread width, on the rear axles on a narrow front, and on both front and rear axles on a row crop wide front. They also generally (there are exceptions) use taller rear tires for added crop clearance, and dropped spindles on the wide fronts. Narrow fronts have crop clearance built in by virtue of their pedestal design.
Standard tractors are identifiable by the non-adjustability in their tread width, and general lower profile, as crop clearance isn't as much of a concern, and the designers could concentrate on lowering the center of gravity for safer hillside operation; ie: your Cockshutt 70 Row Crop is a dramatically larger looking tractor than it's Cockshutt 70 Standard counterpart.
j ulmer
04-16-2004 19:15:45
 Re: Re: What is the difference in reply to Dsl, 04-16-2004 14:02:55
A very succinct, concise explaination!!
