Starter Problem?
steve
04-16-2004 11:25:17
I had the starter for my 66 RC rebuilt a couple of years ago and am now experiencing the same problems, it does not seem to engage all the way.
Any suggestions?
Chris
04-16-2004 20:01:34
 Re: Starter Problem? in reply to steve, 04-16-2004 11:25:17
If the gear on the end of the starter isn't going into the flywheel you may want to clean it up. If you oil them (which I love to do) they will eventually start sticking one way or the other. I have also had bad connections on a switch or the swith itself go bad and it would act up. Check and clean you connections first and you may want to do a voltage drop across the switch. If that doesn't work pull the starter out and bench test it to make sure it is kicking out all the way. Let us know how things work out. Good Luck.
steve
04-20-2004 07:15:50
 Re: Re: Starter Problem? in reply to Chris, 04-16-2004 20:01:34
We ended up pulling the starter and upon taking it apart we found one on the bolts inside had loosened and was arcing to the armature. I have been told that this problem is not uncommon.
Thanks for your help!
chris
04-20-2004 07:17:05
 Re: Re: Re: Starter Problem? in reply to steve, 04-20-2004 07:15:50
Glad you got it going again. Have a nice day.
