Oliver 880 Power Sterring Help??
Mitch
04-15-2004 09:02:10
I have an 880 Power steering pump and narrow front-end would like to take off to sell or use but can't figure out how to get HydrGemmer Unit(SP) under radiator off got top snap ring out put still not coming any help would be appreciated.
J. Schwiebert
04-15-2004 09:10:14
 Re: Oliver 880 Power Sterring Help?? in reply to Mitch, 04-15-2004 09:02:10
Put the snap ring back in there. Then loosen the 7/8 nut/ when it gets tight, keep going it will then loosen the unit from the tapered splines It is a puller bolt used to tighten and loosen the unit
Mitch
04-15-2004 09:16:22
 Re: Re: Oliver 880 Power Sterring Help?? in reply to J. Schwiebert, 04-15-2004 09:10:14
Tried looseing nut before snap ring was off but all it did was trun tires. should i try breaker bar or air tools?? got it soaking in peneatraing oil now
thanks
J. Schwiebert
04-15-2004 15:56:24
 Re: Re: Re: Oliver 880 Power Sterring Help?? in reply to Mitch, 04-15-2004 09:16:22
Mitch;
If I remember right the torque on that bolt is 175-200 foot pounds. I always used a good 1/2 inch breaker bar but I also hava 3/4 drive long ratchet that works too. Questions?
