Missing Hyd oil
alberta dave
04-12-2004 08:11:49
I had a cracked hydraulic hose and bad o-ring on the hydraulic flow control valves under my 1850's seat for most of the winter. I changed them out last month and added about 10 L to the hydraulic tank thinking I would be good for a couple of months, but noooo... I have added yet another 15 liters of hyd oil in the past two weeks and I can not find a significant leak to account for the fluid loss. Can Hyd oil leak into the transmission gear box if a shaft seal has failed? I had thought that the pan under the pump would prevent any hyd oil from getting into the gearbox but I am running out of places to look. I even rode in the bucket while my wife drove to see if I could spot a leak from the streering mechanisum. Nothing but normal seeps and drips common for a 35 year old tractor underneath.
hardscrabble
04-12-2004 19:03:17
 Re: Missing Hyd oil in reply to alberta dave, 04-12-2004 08:11:49
Neighbor had an 1800 with the same problem. Rear axle bearing had gone out, and the bull gear wore a hole in the resevoir.
Wayne
04-12-2004 16:20:08
All you have to is check your transmission oil and see if it is over full. If it is bingo you know where it went.
Sam M
04-12-2004 11:14:43
I had this problem on a 1555 which I believe is set up the same as the 1850 . Three possible causes : (1) hole in the hydraulic oil pan ; (2) breakdown in gasket which seals the pan to the top - there is an area in front of hydraulic oil filter but before gear shift where a bad gasket could allow hydraulic oil to leak from reservoir into the transmission ; (3) bad front seal on hydraulic pump . You drain the gear oil for the transmission and rear end on this tractor in two places , (1) a recessed pipe plug (1/2 drive ratchet with no socket will fit in plug ) underneath the transmission right beside the pipe plug which allows removal of the screen to the transmission oil pump and (2) a recessed pipe plug underneath the rear end . If I recall correctly the plug under the rearend is directly above the draw bar so you have to swing the draw bar right or left to get to this plug . Remove both plugs and drain the fluid from the transmission and rear and and I am pretty sure you are going to have both hydraulic fluid and gear oil mixed together . I would have several five gallon buckets ready because if hydraulic fluid is mixed with gear oil in the transmission and rear end you are going to have a lot of fluid there .
A guick way to test which of the three causes it MIGHT be is to leave the plugs out , put clean buckets underneath each plug hole and then add some hydraulic fluid . If fluid leaks into the front bucket underneath the transmission , it is more likely a bad gasket or the front seal on the hydraulic pump . If fluid leaks out of the rear hole (under the rear end ) it is more likely a hole in the hydraulic oil pan . If you get no leaks with the tractor off , it is most likely a bad seal in the hydraulic pump which is only leaking when the pump is turning . ( However , on my 1555 the leak was the seal on the hydraulic pump but it was slow leaking when the tractor was off , not when it was on - go figure that one ) . My guess is you are going to have to take the top of to figure out and correct the problem .
alberta dave
04-13-2004 06:18:18
 Re: Re: Missing Hyd oil in reply to Sam M , 04-12-2004 11:14:43
Thanks for the comments, I will tackle this over the weekend and post results.
J.
04-12-2004 14:26:10
Sam 1750 series and up if equipped with a 3 point have the dashpot rod as Larry suggested. 1550, 1600 and their replacements do not use that set up.
Larry from MD
04-12-2004 08:49:26
Yes hydrolic oil can get into the rear.It can leak out the pump seal or through a crack in the pan or the seal if you have the dashpot push rod through the pan.open the filler leval plug on the rear to find your oil.
