Oliver engine what is it??
old
04-09-2004 16:11:44
I'm looking at buying an engine its an oliver looks to be out of a tractor but been used as a power unit. Its 4 clyinder, the hood slants on the front like on a 70, couldn't read the numbers on it, so what might it be out of? And will it fit in a cletrac HG?? Thanks for any info
BILL
04-11-2004 14:27:29
 Re: Oliver engine what is it?? in reply to old, 04-09-2004 16:11:44
I NEED A CONTINEL F 124 OT LARGER BUT SAME BOLT PATTERN . WOULD YOU BE SELLING YOUR CONTINENTAL ????
old
04-11-2004 14:34:11
 Re: Re: Oliver engine what is it?? in reply to BILL, 04-11-2004 14:27:29
Well I may sell the 4 cylinder in the cletrac but I also have a 6 cylinder in a road roller that I would sell, both engines run well. The 6 cylinder has mag ignition and the 4 cylinder is battery type
BILL
04-11-2004 14:41:00
 Re: Re: Re: Oliver engine what is it?? in reply to old, 04-11-2004 14:34:11
WOULD ONLT NEED THE 4 CY IF ITS A F SERIES FOR MY CO-OP MODEL C WHERE ARE YOU LOCATED AS FREIGHT IS GETTIG SO HIGH
old
04-11-2004 14:44:34
 Re: Re: Re: Re: Oliver engine what is it?? in reply to BILL , 04-11-2004 14:41:00
Its believed to be an F series, but unsure of which one/which size. I live in Missouri close to the lake of the ozarks
J. Schwiebert
04-09-2004 18:08:32
Most likely an Oliver 60 engine. Look at the engine. Is there a cast flange at the rear of the engine which supports the starter with two bolts? Also on the spark plug side of the engine you should have some good size soft plugs like over two inches in diameter and I think there are three of them. As far as fitting the HG crawler. The crawler was designed by the Cleveland Tractor Company before World War 2 and before Oliver ever entered the picture. The 60 Tractor is an Oliver. The Crawlers except for the AG-6 & OC-6 used HERCULES ENGINES. The wheel tractors except for the 70 at that time were all Waukesha built. So is it a "drop in" I doubt it.
old
04-09-2004 18:23:49
 Re: Re: Oliver engine what is it?? in reply to J. Schwiebert, 04-09-2004 18:08:32
Hi J, it did have a 2 bolt starter and it looked like it was in a cast iron frame so to speak, it did have a number plate on the left side front of the engine but I didn't have pen or paper on me to write any thing down. How hard are the parts to find for them?? I know it wouldn't be a drop in as far as the HG but I think it would be better the the continetal thats in it.
