770 Power Boost won't stay in high
Ron
04-07-2004 21:11:06
I have a 770 with the power boost option (provides 12 speeds) and it does shift into high but won't stay there, when you let go of the lever it shifts back into low. Any ideas on what might be the problem? I am assuming it should stay in high gear without having to hold it there? I am hoping an adjustment of some sort might fix it?
Scott Green
04-08-2004 03:31:57
 Re: 770 Power Boost won't stay in high in reply to Ron, 04-07-2004 21:11:06
Sounds like ajustment to me. You will need to take out shims under each of three spiders at clutch. 21 shims in each shim pack. You will need to take out about 3 or 4. This is how you ajust that clutch. Plan on at least half a day , if you have never done this before. It can also be a badly wore/broken yoke assembly. Under galleries at the left colum "Parts and Pieces" , do a serch. Type in 1960 oliver 880. If you have any questions , feel free to e-mail me.
