Scottf more help for 990!!!
ghh
04-05-2004 08:18:04
Once again I have hit a snag. I have a parts manual, engine manual, operators manual, but the shop manual I bought is not very good for the money I spent getting it. Some info but no pictures showing assembly. So once again I need your help. I'm replacing the fuel tank and need to know if there is only a rubber support about 7" in length that supports the rear of the tank. I also would like to know how the wiring is reattached under the tank. I was trying to be careful while taking it apart but to much time has past. Thanks I know I will probably need more help in the future.
scottf
04-05-2004 19:26:10
 Re: Scottf more help for 990!!! in reply to ghh, 04-05-2004 08:18:04
Yes, there is a chunk of rubber that goes under the fuel tank in the rear.
I use rubber coated elec wire hanger clips you can get at NAPA for running wire under the fuel tank. They are similar to what they used originally except they were originally wrapped in some kind of cloth instead of rubber. They come in different sizes I believe I use 3/4". The fuel tank has 6 studs under it. Attach the wire clips to the studs tucked up under fuel tank. Run wires, cables and hose (oil pressure gauge) through them. Maybe another photo would be good?
