oliver 66 questions
Hammer
04-04-2004 14:01:03
1)On my oliver 66 (SN 424918C660), the power take off lever is on the right side of the operators seat as viewed from the rear of the tractor. My manual says it should be on the left. Any explanations? 2) My oliver has the hydraelectric option. But when I got the tractor, the reservior is empty. Can I leave it empty without damaging anything if I do not hook the hydraulics up? 3) I assume the oil fill for the belt pulley drive is on top of the pulley shaft housing inside and under the hood, but no where in my manual does it say how full or with what oil I use. I assume it is SAE 90, but how much does it take? 4) My oliver was green when I got it, but while restoring it, I see yellow under the green. Looks like the whole tractor was yellow. Anybody got a spot where I can look at what the original colors were on this tractor? 5) My power take off reservior is empty. Do I fill through the oil level check hole? thanks all.
J. Schwiebert
04-04-2004 15:18:10
 Re: oliver 66 questions in reply to Hammer, 04-04-2004 14:01:03
Original PTO handles were on the left side. When the new seat was introduced they were moved to the right. Keep oil in the hydraulic. The PTO drive shaft drives the pump. It runs anytime the engine runs. I need to think about the pulley. They were almost a thing of the past 40 years ago. It is 90 weight oil. Splash from normal operation will put some in there. Are you planning on using the pulley for extended time spells? On the PTO yes, unless you have the drive shaft out then pour it in from there. Check the oil level in the rear end. That may be where your hydraulic fluid is going and too much oil and it shortens the life of brakes as the bull pinon seals will start to leak. Questions/
dan
04-04-2004 15:17:31
all the 66,77,&88 that we have have the pto lever on the right side.the hydraulics will need fluid in them, any time the engine is running the pump is turning. if the system is dry chances are the pump has froze and broke, allowing the hyd. fluid to drain into the trans.i'm not familiar with the belt pulley. the yellow under the green i believe is a primer.the pto can be filled through the level plug hole. hope this helps some.good luck.
