2255 hyd PTO
Jim Meade
03-31-2004 10:56:31
I have a 2255 that has been hard to shift the PTO between 540 and 1000. It has also been taking a lot of hydraulic oil. When I drained the transmission and differential, I found very few filings but found two brass rivets. Dealer says they're from the PTO brake.
A very good mechanic I know says the most likely place for the leak is the seal on the hydraulic pump. If any of you have any experience or this sounds like something you've heard about, I'd like to hear what you know.
Thanks.
Wrenchbender
03-31-2004 11:12:31
 Re: 2255 hyd PTO in reply to Jim Meade , 03-31-2004 10:56:31
Jim, The rivets are most likely from the PTO brake. The old brake material was riveted on and the new style is bonded. If your rearend is being overfilled with hyd oil it is most likely coming from the PTO. Since you have found the rivets that hold the brake lining on, there's a good chance the lining is gone and the brake piston is pushing out farther than normal. You can isolate the PTO by capping off the line going to the pto control valve. If the oil level stops rising the PTO is the leak. WB.
