880 - fix or part out?
Jim Meade
03-29-2004 14:49:08
I bought a 1960 880 NF gas the other day 4000 hours (pretty cheap). Was shedded but has not run for many years (maybe 10?). Sheet metal is very good and decals and plastic hood ornament are unbroken. Has extension on fenders. Lights are good and complete except one is missing. Was told the engine is OK, but who knows? No obvious dirt or oil leaks showing. Exhaust manifold is good. Fresh oil and no water in crankcase. No water in radiator. Hydraulic unit empty, so maybe seals gone? Dual hydraulics. PTO has very little slop. Dirt built up so don't know if the rear rims are OK or not. I'm guessing it didn't run fluid. Cover is off the clutch. Was told the clutch and power booster were OK but don't know. I'm suspicious on that. Rubber is all rotten. Was used on a loader and has three sets of weights on the rears.
Green 88
03-29-2004 16:46:18
 Re: 880 - fix or part out? in reply to Jim Meade, 03-29-2004 14:49:08
Jim, please let me know if you are going to part it out. Thanks, Jason (906)635-7261
Ed
03-29-2004 15:06:40
Jim, Give me a call on 880 563-927-4919 Ed
