ring gear from 77 Oliver
John
03-27-2004 15:21:14
I came across an extra ring gear for a 77. It has 48 teth.....#1106 I believe....What's this thing worth, it's in fair shape, no chipped teeth. Thanks in advance...John
Matt
03-29-2004 19:19:25
 Re: ring gear from 77 Oliver in reply to John, 03-27-2004 15:21:14
#1106 does not match up with anything on a 77 that I can find. The ring gears came in sets with a pinion gear that drives it. There are several different sizes of pinion gears that come with a 48 tooth ring gear. There were 9 tooth pinions, 13 tooth pinions and 14 tooth pinions. All had 48 tooth ring gears of different pitches that allowed them to mate up to the pinion gear. It is very important to keep a ring and pinion "set" matched up as they will wear evenly on each other. The 9/48 tooth set was a slow geared tractor. The 13/48 was a little faster and the 14/48 was the fastest of all. Oliver used the 14/48 in most of the standard tread tractors to make the ground speed of a standard tread tractor similar to a row crop tractor which used the 9/48 and 11/50 set up. The standards had smaller diameter tires and wheels, so this was necessary to make speeds similar between row crops and standards. Bottom line, if you have a 14/48 ring and pinion I would be interested. Email is attached.
