Hydraulics problem
jack
03-26-2004 08:28:01
I thought I would check the hydraulic oil in the Super 88 and it didn't touch the stick.I poured some in and kept pouring and never did top it off.I pulled the rear check plug on the rear end and it was way over full,what a bummer.While there was fluid the hydraulics they worked good,just couldn't keep oil in it.Would a seal leak it out that fast?
Jeff
03-27-2004 19:43:42
 Re: Hydraulics problem in reply to jack, 03-26-2004 08:28:01
hey jack from what i have read on here i seems to be a common problem with the unit for the seals to leak. As oleblu said it is usually either a seal or the plate. If it is the plate hollar at me when/ if you get it down , we might be able to fix it. Also hollar at me some time this week and we'll try to get your wheelie bard finished.
oleblu
03-27-2004 05:01:34
jack, yes, your seal could be the problem although the center plate of your pump may be cracked. The only way to tell is to remove the pump and look. Been there, done that. If you have more questions, drop me an e-mail. oleblu
