Missing Parts
Steve
03-24-2004 18:37:00
I am missing (2) parts to complete my engine. I have a White 2-63-15 TLB with a Oliver 232 cid 6 cyl diesel, missing is the injector pump cover on the front it is approx 8 inches in dia. Also and much more important is the rear seal retainig cover. It bolts to the back of the block with a U-shaped gasket flange between the block and the flywheel It holds the rear seal and also bolts to the oil pan ,it directs the oil back into the pan. The transmission housing may also bolt to this? I'm not sure though. This engine is the same as the 1550/1555
Wes Dorhout
03-25-2004 07:20:47
 Re: Missing Parts in reply to Steve , 03-24-2004 18:37:00
I have the parts you are looking for. E-mail or call 712-324-2760
