oliver/perkins puller?
KB
03-24-2004 18:08:12
I have an 1850 that i'm thinking about setting up for pulling. I also have several perkins engine parts. I want to put a perkins dot4 head on a 372 block with a turbo. The class is 8500lb and a 3000rpm with 410 cid rule. Do you think this will compete against 1206 ih and 970 cases? any input would be apreciated. Thank you
m kuhns
03-25-2004 06:29:13
 Re: oliver/perkins puller? in reply to KB, 03-24-2004 18:08:12
We are running right around 200Hp out of our 1850 with the original 354. We added a 5.9 Cummins turbo and put a larger head in the pump. If we had more fuel I'm sure we could get quite a few more ponies as the pump was maxed out. A charger off of a newer 5.9 should give you 30psi boost . With the wastegate hooked up it will run about 22psi which was enough to make about 200Hp. Had enough to win the 11K, 13K, and 15k classes at the one fair competing againt about 30 tractors in each class. Most of them were red 1066's. You should be able to get well over 200hp if you do all the other things you say.
Brad
03-24-2004 20:42:06
A guy I work with put a set of international pistons in a prekins, I think they were 1206, but they were 4 1/8 bore, making about 410 cubic inch. the new massey head is by far the best head for that engine, the late 1006 perkins engins. the head will bolt right on and it is a 12 port head. the manifolds, injectors and camshaft are also different. a roosa master will go right on a 2-105 style drive and work alot better than the cav and look stock.
KB
03-25-2004 16:23:06
 Re: Re: oliver/perkins puller? in reply to Brad, 03-24-2004 20:42:06
I didn't know that a roosa master would fit. Is it a real big job to change over? thanks
Brad
03-25-2004 19:12:53
 Re: Re: Re: oliver/perkins puller? in reply to KB, 03-25-2004 16:23:06
No, it's pretty simple. The adaptor plate needs to be machined down so that it's a little thinner, but with the pump assembled with the correct parts, it bolts right on and looks stock. I use the electric shutoff rather than the cable because the external lever hits the block. just make up a set of lines bent just like the originals and you can't tell that it's not stock.
J. Schwiebert
03-25-2004 18:14:03
You got my attention here too, but You got more of my attention on the horizonal pump drive on a dot four, I can see it on a "phaser' but how on a dot 4?
WFE
03-24-2004 19:45:12
Interesting... The question I would have is if you can add a turbocharger to a tractor that was originally naturally aspirated. When limited in displacement, you want to make the most of what you're allowed to have by optimizing engine efficiency by burning as much fuel as possible. More fuel requires more air. To an extent, valves and head work can help, but turbocharging should really make that Perkins a monster, with some pump work perhaps too. An 1855 with the turboed 310, even though smaller in displacement, may have a slight edge. High rpms help the 310, but even at 3000 rpm, you should be able to do pretty respectably against 1206s and 970s. Wish I could impart some experience, but I've never juiced a Perkins. I'll be waiting to hear what others can add on this topic, as I'd like to know what the secret is to a 250hp tractor under 10,000 lbs farm stock.
Marc Smothers
03-25-2004 14:37:58
 Re: Re: oliver/perkins puller? in reply to WFE, 03-24-2004 19:45:12
I know it is bit of subject as far as the Perkins goes. A gentleman bought my 1855 project that I was repowering. He will get close to 600hp. with the 5.9L cummins. He turned the whole tractor to a White 140 and he is goinhg to be pulling under 8000lbs. YOu can get a whole lot more than 250hp under 10,000 lbs. Just my 2 cents about the power
luther
03-26-2004 19:02:03
 Re: Re: Re: oliver/perkins puller? in reply to Marc Smothers, 03-25-2004 14:37:58
If a man had the funds, why not repower with a newer computerized Cummins? Supposedly you can change computer chips for whatever horse you need. I was curious about the Perkins and what could be done to make it turn that kind of horse. The class your talking about sounds like the pro-field class around here. The red ones are dominating the 8200 and the 10200. I think 410 is the limit on the 8200 class but 10200 is unlimited. Our brand gets laughed at around this area so I hope you can blow smoke and kick some red and "other" green you know what!!!
ol George
03-24-2004 20:29:16
I think I would use a dot4 motor. The pump placement would be a plus and the head is way better. I prefer the horizontal pump if at some point you want to go to a faster class, it would be easier to mount an A or P pump.
