Oliver 550 noise, Mechanic needed!!
Dan J
03-23-2004 05:50:43
I just picked up a nice original 550 but it has a noise in the engine (Rattle/knock) when it gets warm. Seems to be coming from the oil pan area and gets worse by pulling any spark plug wire. Any ideas before I go pulling the pan? Thanks, Dan
ol George
03-23-2004 18:14:25
 Re: Oliver 550 noise, Mechanic needed!! in reply to Dan J, 03-23-2004 05:50:43
I know this will sound crazy, take a wooden stick we use a tobacco stick, start the motor and put the stick up to the engine and the other end to your ear with your thumb over the end. This will allow you to hear the engine working, I have been able to tell which valve was bad, a click in a turbo and a knocking rod. Cheapest diagnostic tool I have ever found. Best of luck.
Dan J
03-25-2004 00:46:32
 Re: Re: Oliver 550 noise, Mechanic needed!! in reply to ol George, 03-23-2004 18:14:25
Thanks George, That narrowed it down a little, sounds like it is coming from a little behind the timing gear cover but the noise comes and goes. Wrist pin on #1 maybe?
