Horsepower
Jimmie Castex
03-22-2004 12:32:31
How many HP does a 1650 have?
Russ
03-24-2004 16:57:51
 Re: Horsepower in reply to Jimmie Castex, 03-22-2004 12:32:31
OLIVER 1650 hp?
265 CID GAS 66.7 PTO HP 7022LB RIG NOT 4WD
283 CID DIESEL 66.2 PTO HP 7143LB RIG NOT 4WD
Bill Barlow
03-23-2004 12:20:32
How many hp does an Oliver OC-3 have ?
How much does it weight, It is on tracts and has a blade on the front.
Certified
03-22-2004 16:54:47
66PTO HP
ShepFL
03-22-2004 13:38:10
To the best of my knowledge they were rated at approx. 65 HP
orvile
03-22-2004 18:14:49
 Re: Re: Horsepower in reply to ShepFL, 03-22-2004 13:38:10
How about a 1600 diesel? Any preference between a gas and diesel?
Don-Wi
03-22-2004 20:02:10
 Re: Re: Re: Horsepower in reply to orvile, 03-22-2004 18:14:49
I think they are rated around 58, my 1600 gasser will have a few extra when I'm done, I put in a 3&3/4" overbore kit, and had a complete head rebuild w/ Lp ex. valves and hardened seats, kept original int. valves, all new springs, guides, etc... Basically it's a brand new engine, minus the conecting rods. I might try to see if I can have it tested on a dyno once it's runnning
Donovan from Wisconsin
bernie ks
03-22-2004 21:45:00
 Re: Re: Re: Re: Horsepower in reply to Don-Wi, 03-22-2004 20:02:10
What is a 1600 worth with 1300 hrs one owner good tires excellent paint and tin but has a bad valve it is gas?
Russ
03-24-2004 17:02:51
 Re: Re: Re: Re: Re: Horsepower in reply to bernie ks, 03-22-2004 21:45:00
1600 GOING AWAY; WORTH SOMEWHERE IN THE NEIGHBORHOOD OF 2700 OR MORE TO THE RIGHT BUYER.
