Super 55 fan pulley trouble won't go away.
Paul
04-29-1998 22:15:06
I am still perplexed with my fan pulley alignment. I have definately decided the generator and the crank pulley are lining up fine, but that darn fan pulley needs to come forward abut 3/4" (that means a shorter hub on that pulley). I anin't going to run that thing unaligned, but can't figure out why it is out. The water pump is the right one, and the spacer that goes in front of the pulley is correct too. The pulley itself measures 2 5/8" from the front of the pulley to the back of the hub, but it would be correct if it was 1 7/8". Could someone with a Super 55 diesel measure theirs and let me know what size there pulley is? If worse comes to worse I'm going to machine one that fits, but I would really like to keep everything original. thanks in advance.
Paul, problem solved
05-03-1998 21:12:07
 Re: Super 55 fan pulley trouble won't go away. in reply to Paul, 04-29-1998 22:15:06
Thanks for the people who replied. The problem was that the replacement waterpumps are after market and not exactly the same. One reply was to use the pulley off of a simplicity mower. Cut it to size and drill the mounting holes. I may try that, but first I'm going to weld one up, using my old original hub, and machine a new belt pulley.
I am so glad we have this site to share information. Two (or more) heads are better than one!
