White 2-150 cummins repower
Kevin
03-21-2004 17:56:34
I have a 2-150 with a 585MM and am thinking a bout putting a L10 cummins in it I think it would be about the same dimensions as the 585.
If anyone has any information on this let me know thanks
Kevin
03-24-2004 17:55:00
 Re: White 2-150 cummins repower in reply to Kevin, 03-21-2004 17:56:34
The reason i want to go with a cummins is because of the cost and availability of the 585 parts. And i want it to look like it did, as much as possible, as it did from factory. So a 5.9L isn't going to do it. I think you can run a L10 at 210hp without a turbo, and there cheap to buy and fix.But i haven't measured on to see how well they fit. thanks for the input
Warren Moeller
03-22-2004 11:38:21
An L-10 is a lot of engine for this I have one ina 4568 IH and we run an easy 300hp all you need for that tractor is one out of a dodge truck 5.9 they will an easy 200-225 hp and their are conversion kits for them we have done these in 1850 and seen in an 856 ih and they have way more than enough power
Toocold
03-22-2004 16:46:37
 Re: Re: White 2-150 cummins repower in reply to Warren Moeller, 03-22-2004 11:38:21
Interested in the conversion kits for the 5.9 cummins.
I have a new one and want to put it in a 570 Cockshutt in the near future. Are the kits available for a Cockshutt 570?
Thanks,
Warren Moeller
03-23-2004 05:56:18
 Re: Re: Re: White 2-150 cummins repower in reply to Toocold, 03-22-2004 16:46:37
call Irv Lange at Kunau Imp Preston Ia he can set you up 563-689-3311
Merlin in Saint Louis
03-21-2004 20:30:56
Hi, Kevin! I re-powered a 2-150 back in 1996 for a farmer from Gonvick, Minnesota. I installed an 8.3 Cummins with 205 hp. It was an incredibly involved project, as he wanted to keep the original M-M front frame and axle. In retrospect, I would have campaigned harder for using a 2255 front frame, and then making sheet metal to accomodate the changes. It made a real rip-roarin', buck-snort of a tractor, but it was also a huge expense. In my opinion, the 2-150 was the nicest riding tractor White built, due simply to the long wheelbase. I overhauled one in 1991, and installed some .040" oversize pistons. This made a nice, powerful tractor out of it. Best wishes on your project!
Merlin
m kuhnns
03-21-2004 18:04:25
The 585 MM is closer in dimensions to a 855 although both would be overkill power wise. Anything over 225hp would be too much too farm with. It would be awful difficult to put in since the engine serves as 75% of the frame. The over under is mounted in a special adapter to mount up to the 585. An 8.3 would be suffecient power wise but a lot smaller in dimensions. It would probably fit between the frame rails better.
Marc Smothers
03-21-2004 18:12:46
 Re: Re: White 2-150 cummins repower in reply to m kuhnns, 03-21-2004 18:04:25
I may be way off. But if you are going to go through the conversion why not swap in an Oliver tub for 2255 or etc.. I am sure making the sheet metal work would not be big deal. YOu could use an 8.3L it would be not much different than a White 185 then except for the planetaries. Just a thought. Marc
BigART
03-22-2004 14:42:59
 Re: Re: Re: White 2-150 cummins repower in reply to Marc Smothers, 03-21-2004 18:12:46
A neighbor ran a 585 moline about 15 years ago, with a to6 charger, and 24.5's dualed on the axle. He puller a 24' disk and a 27' packer, the ring and pinion lasted about 350 hours, best i remember it dynoed around 215 hp. That's probably more than the drive tran wants, if it's going to be loaded heavy.BigART
