cummins swap parts
Brad
03-21-2004 10:46:06
How much interest would there be for a aftermarket cast iron flywheel housing to bolt on the back of the b series cummins and a front engine mount that bolts directly to the perkins frame? I know that it is not too much of a challenge to put them in now, but I have connections on getting these parts made and was curious on how much demand there would be.
Marc Smothers
03-21-2004 11:15:44
 Re: cummins swap parts in reply to Brad, 03-21-2004 10:46:06
I am certainly interested in the idea. Although I still like the aluminum clutch housing. If you can make motor mounts that would be easier than me doing it myself. I have parts for a cummins conversion, but put them on for sale as I was going to put 354 Perkins into my 1850. But if someone is making these mounts I might reconsider the motor situation. Thanks, marc
alberta dave
03-22-2004 07:00:11
 Re: Re: cummins swap parts in reply to Marc Smothers, 03-21-2004 11:15:44
I have two 1850's that need new engines but only 1 rebuildable Perkins. I would certainly consider looking at a set of mounts to make the swap more of a drop in and bolt up job. There are a lot more B series cummins out there than 354 Perkins.
perkins
03-25-2004 20:05:10
 Re: Re: Re: cummins swap parts in reply to alberta dave, 03-22-2004 07:00:11
I think 354 perkins are easy to find. Alot of Massey combines have them as well as White combines and massey tractors. All you have to do is change over the adapters from one engine to the next. I have an 1850 with a 1130 massey tractor engin in it.
