Oliver 66 ???
Hammer
03-21-2004 06:36:45
How do you relplace the fan belt and the generator belt. I'm a new Oliver owner and it appears you need to remove the water pump. Am I missing something? Also, I live in Rochester, NY does anyone know a good place to get Oliver parts locally? TIA
Jared Chaddock
03-23-2004 09:29:45
 Re: Oliver 66 ??? in reply to Hammer, 03-21-2004 06:36:45
Hammer- I live in Batavia, NY and we have a pretty good collection of Oliver parts and tractors. Email me with your needs and if we dont have it, we know of alot of other locals that might.
Geoffrey in KS
03-22-2004 17:42:11
I guess you realize that you can release the tension on the belt by loosening three bolts in the crankshaft pulley and then turn the back flange. If you still can't get the belt off, loosen the four fan bolts so the pulley can drop down a little.
Scott Green
03-22-2004 17:34:57
Hammer , I live about 43 miles south of Rochester , NY. You can buy parts at CORYN FARM SUPPIES. They are located at 3186 Freshour Road. Canandaigua , NY 14424. The phone number is: 394-4691. I buy most things from Maibach Tractor(Ohio). The phone number for Maibach Tractor is: 1-800-808-9934 or 1-330-939-4192. Maibach tractor is very nice to deal with.
Jeff
03-21-2004 07:18:16
I have a77 and a 88 but not a 66 but unless there is something built alot different I would say you should be able to wind them over the fan but if not you should be able to just unbolt the fan and replace them that way. There whould be 4 bolts on the face of the fan.
