OC-3 fixing advice
Bill Thornton
06-06-1999 10:04:31
I broke all the studs holding on the rignt side drive unit. I was able to easyout the broken stubs. The real question is what to do with these 6 oblong holes in the transfer case? Drill over size and tap to 5/8"? They were 1/2" coarse into the case and 1/2"fine sticking out.Can I replace with bolts instead of studs?
Albert C. Duroe
06-06-1999 17:19:58
 Re: OC-3 fixing advice in reply to Bill Thornton, 06-06-1999 10:04:31
Yes you can use bolts. You can drill out to 9/16" or use a lock tight product(it has two parts) or heli coil the holes. I would be happy to visit with you 319 827 6140 after 6;00
