Pump work on a 2150
IK
03-13-2004 16:27:41
Does anyone know what the difference in the pumps are between a 2150 and 2-155 white. Did they change the pump heads, the plunger, the injectors. I have a 2150 that i want to pull but it doesnt seem to have enought power to pull with the 1066 IH in the 15500 pound class. It's only pulling 130 on the dyno now. I know that the White 2-155 had the same engine but supposedly they had something different in the pump. I would like to get the hp at least equivlent to the 2-155 whites. Thanks for any help.
luther
03-14-2004 20:26:59
 Re: Pump work on a 2150 in reply to IK, 03-13-2004 16:27:41
Go to the Roosa-Master. You won't believe the difference. The change is not that difficult, either. It sounds like a lot of trouble to change but it's really not and the results are worth it!
IK
03-15-2004 08:57:24
 Re: Re: Pump work on a 2150 in reply to luther, 03-14-2004 20:26:59
Do you know how much a Roosa-Master pump costs and the parts to change it.
J. Schwiebert
03-14-2004 08:39:37
If you go with with the Roosa you will need the fuel lines, front cover and timing gear for the pump drive too. The bosch runs at crankshaft speed the Roosa at cam speed.
IK
03-14-2004 10:14:15
 Re: Re: Pump work on a 2150 in reply to J. Schwiebert, 03-14-2004 08:39:37
Sounds like a lot of work just to change pumps. Do you know where i could get an intercooler and the heads off the generators. And how much it would cost.
Lee W
03-14-2004 06:48:45
I have a Rosa Master pump for a 2-155 if you would be interested, it is turned up for pulling.
IK
03-14-2004 10:12:34
 Re: Re: Pump work on a 2150 in reply to Lee W, 03-14-2004 06:48:45
I might be interested in the pump. I depends on how much you want.
Lee W
03-14-2004 20:20:23
 Re: Re: Re: Pump work on a 2150 in reply to IK, 03-14-2004 10:12:34
I might have most of the parts it would take to change it over. We had one break a crank so we have some extra parts as we put a complete engine in it.
J. Schwiebert
03-13-2004 19:30:13
IanC is correct. A 2050 will run that much horsepower. Are just going to just pull the tractor? We had one around here that ran 200 Horse and there probably more there, but if you are going to farm with it you will crack exhaust manifolds like crazy. You might want to get in touch with Jerry Biro too. Hercules also sold that engine for generator sets with an intercooler and he can probably find one for you. Another thing. I did a cylinder head rebuild class for the West Virginia National Guard on the 465 (Military Version of the 4800)about 10 years ago. those engines had stress relieved heads for the extra heat and horsepower. If you can pick up a surplus engine do it. There are neat little changes in those engines that makes for a smoother running higher reving unit. Just FYI
IanC
03-13-2004 17:08:11
If you have a 2150 that's only 130hp something is seroiusly wrong. The ratings Oliver gave were always conservitive. The engine is capable of 250+HP. I know this as we had a customers machine that had been souped up on our M&W P200 dyno (good to 200hp) and it blew up the dyno when we pulled it down to max torque and the reading was well past the 225 mark and the engine wasn't even snorting. The engine in the 2150 was a Hercules DT4800, the ones in the 2-135/155 were DT5000. I'm not familiar with the Bosch pumps on the 2150's, but when I went to Stanadyne school they said the DM series pump from the 135-155 was good to 40hp per cylinder naturally aspirated.
J. Schwiebert
03-13-2004 16:33:50
Well for one thing the 2150 uses a model 100 Bosch pump and the 2-155 uses a Roosa Master pump
