Cockshutt Gauges
RL
03-13-2004 06:01:39
Where can I find new reproduction gauges Oil, Temp & Battery for a Cochshutt 30? May settle for good used ones.
Tony Sha
03-14-2004 09:13:08
 Re: Cockshutt Gauges in reply to RL, 03-13-2004 06:01:39
While we are on the subject of gauges, does any one make a repo gauge with a Cockshutt script on the face? I have eleven tractors (Cockshutt & Co-op)with mostly original gauges but only one that has a script gauge. I assume it's an old dealer replacement??? Sure would be cool to have a set of repo script gauges!
RL
03-14-2004 16:11:24
 Re: Re: Cockshutt Gauges in reply to Tony Sha, 03-14-2004 09:13:08
For Tony Sha,
Did you say 11 Cockshutt and Co-ops? I just purchased my first Cockshutt 30. Man, I wish you were close by in FL. Hope to get it running this week. This Distriutor is all messed up and I just purchased one from Irv in PA. Sounds like a real decent guy. Real tolerent with all my learning questions. Have you converted any to 12V? Mine has a 12V alt and I am trying to decide if I should use a 12V coil or a 6V coil with the resistor. It guess it's no big thing, just preference.
Tony Sha
03-14-2004 18:54:34
 Re: Re: Re: Cockshutt Gauges in reply to RL, 03-14-2004 16:11:24
Owning 11 Cockshutts (or any old tractor) is just a lack of good sense. I probably have 11 times the problems you have. But I love it, it keeps me out of the bars and I was a mechanic for 20 years so that helps. As far as the 6 or 12 volt thing, the voltage of the generator and the coil must be the same. Just remember, if the battery is neg. ground the coil must be neg. ground also. (coil grounds thru the points) I've talked to Irv too, He's a good guy. Good luck!
RL for Tony Sha
03-15-2004 11:48:26
 Re: Re: Re: Re: Cockshutt Gauges in reply to Tony Sha, 03-14-2004 18:54:34
Thanks Tony,
Do you use any resisters between the Battter and Coil?
Tony Sha
03-16-2004 18:12:55
 Re: Re: Re: Re: Re: Cockshutt Gauges in reply to RL for Tony Sha, 03-15-2004 11:48:26
on a 12 volt system...yes, but not on a 6 volt
Keith Hewer
03-13-2004 19:04:28
We supply guages for the cockshutt tractors, grills and screens, battery boxes, dash light, steering u joints, head lights, steering wheeels, seat cushions carb kits, decals and books. We also have the decal for the battery. We also part out tractors in the cockshutt line. Thansk Keith @ [email protected]
RL for Keith
03-14-2004 07:28:57
 Re: Re: Cockshutt Gauges in reply to Keith Hewer, 03-13-2004 19:04:28
Keith, Would you try that web site again. Looks a little long. Do you publish a catalog? Thanks
P Heisey-Harleysville,PA
03-13-2004 15:34:05
RL,
YES, I have new gauges on stock for your COCKSHUTT 30 Tractor. They are like the originals. I also have many other parts for you Cockshutt. Email or call with your list of needs for my quote.
Jflem, Thank You for posting my contact info.
Phil Heisey 215-256-8651 eve. FAX 215-256-1203
jflem
03-13-2004 06:21:11
get in contact with phil heisey in pa. 641 store rd. harleysville pa. [email protected]
Jerry
03-13-2004 13:12:39
 Re: Re: Cockshutt Gauges in reply to jflem, 03-13-2004 06:21:11
I had decals made for mine that tape over the glass on generac gages.
