E4 CAM TO CRANK TIMING
FRED
03-12-2004 19:11:51
WHICH MARK DO I USE TO LINE UP TO DOT ON CRANKSHAFT WHICH IS ON TOP OFCRANKKEY.BUTA 232CID
Irv
03-15-2004 18:08:27
 Re: E4 CAM TO CRANK TIMING in reply to FRED, 03-12-2004 19:11:51
Fred sorry was gone a couple days, email me directly and I will try to explain what I have and can see best I can. Irv
FRED
03-13-2004 19:38:55
IRV MY MYSTAKE IT IS A 230 BUDA.THE THING IS THE CAM GEAR HAS 3 DIFFERNT PUNCHDOTS AND SOME SORT OF NUMBER NOT CLEAR CIRCLED TRYED USING EACH OF THEM NO LUCK HAD NO COMPRESSION FIRST NOW WE DO AT THIS POINT BUT TIMING IS STILL OFF PUSHING COMPRESSION BACK OUT THE CARB .HAS NO VACUUM.WONT DRAW FEUL TO THE CYCLDERS APROX 80LBS PR CYL WHAT DO I NEED TO DO .CANT FIND ANY PICTURE TO GO BY ,
J. Schwiebert
03-14-2004 06:06:43
 Re: Re: E4 CAM TO CRANK TIMING in reply to FRED, 03-13-2004 19:38:55
Do you have the front cover as well as the valve cover off. When the keyway on the crankshaft is straight up either the valves on number one or number 6 will be loose the othercylinder will be on valve overlap. Turn it one full turn and they will flip flop. Any how see if you can get a set of dots that will give you that condition. I have not done a Buda in 35 years, but on some engines the dots line up a little before TDC. I might have an old picture, want me to look?
FRED
03-14-2004 12:34:47
 Re: Re: Re: E4 CAM TO CRANK TIMING in reply to J. Schwiebert, 03-14-2004 06:06:43
J TAKE A LOOK ANY HELP WOULD BE A GREAT HELP THANKS FRED.
J. Schwiebert
03-15-2004 15:39:11
 Re: Re: Re: Re: E4 CAM TO CRANK TIMING in reply to FRED, 03-14-2004 12:34:47
Send me a U. S. mail address and I will send you what I have.
FRED
03-16-2004 18:01:44
 Re: Re: Re: Re: Re: E4 CAM TO CRANK TIMING in reply to J. Schwiebert, 03-15-2004 15:39:11
J WOULD YOU CALL ME COLLECT IN THE EVENING BETWEEN 6;30-10PM SO I COULD ASK A FEW QUESTIONS ON THIS TIMING PROBLEM AGRAVATED WITH THIS THING NOBODY OLDSCHOOL AVAILBLE LOCAL THAT KNOWS CO-OP E4 BUDA MANY THANKS FRED 812-839-6533 MADISON IND,
Irv
03-13-2004 16:00:05
Fred, if I understand correctly you are working on a COOP E-4 or a Cockshutt 40 with a Buda 230 6 cylinder motor. There should be a tooth on crank shaft gear with a single punched dot. There should be a coresponding punched dot on a single space on cam gear. just line the 2 up. if you need mor email me Irv
