What type oil?
Jack
03-12-2004 12:11:07
I have a super 88 that supposedly had a leak in the hydraulics when I bought it.I was told by the guy I purchased it from that it leaked out of the unit in about two days time.They are plowin tomorrow close by and I was thinking bout takin it.What kind of oil could I use for that day,I am not planning on doing this on a regular basis,just tomorrow?Might not even use the hydraulics if there is a three bottom trip handy.Whatcha think?Jack(TN). P.S.I will eventually fix it.
J.Schwiebert
03-12-2004 13:23:32
 Re: What type oil? in reply to Jack, 03-12-2004 12:11:07
Keep oil in it! Most likely the oil is going past the pump seals and down into the transmission. Even if you do not use the hydraulics keep oil in it or you will ruin the hydraulic pump. A couple of gallon of oil are much cheaper than a pump! 10 or 20 weight would work fine.
