Whtie 2-180 Hubs
m kuhns
03-10-2004 08:16:20
Anyone have a good place to find hubs for a 2-180 white to mount axle duals. It has a 3.88 double keyed axle. Correct me if I'm wrong, but I am thinking that models 2-135, 2-155 and up through the Workhorse series had the same hubs. Do the 4-210 and 4-225 use the same ones too? I would prefer a pair of 10 bolt hub but nine bolt ones would do. Also, what would be a fair asking price? Any info would be appreciated.
Mike
03-11-2004 16:58:56
 Re: Whtie 2-180 Hubs in reply to m kuhns, 03-10-2004 08:16:20
I have a set of 10 bolt hub duals for a 2-180. Call me at 641 682 7754 if you are interested.
Merlin in Saint Louis
03-10-2004 10:28:47
Hello! The following tractors will all have the same size rear axle shafts: 2-135, 2-155, 2-180, 100, 120, 140, 160, 185, 125, 145, 170, 195, 4-210, 4-225, 4-270, 6125, 6145, 6175, 6195. All of them use the dependable, inboard planetary rear end. The hubs should not be too expensive at a salvage yard. We owned a 2-180 from 1979 until 1998. What a horse!!! Best wishes!
Merlin
Dean Barker
03-10-2004 20:57:12
 Re: Re: Whtie 2-180 Hubs in reply to Merlin in Saint Louis, 03-10-2004 10:28:47
Do some measuring; some of the 100 and the earlier 120 and 140 models had smaller (like 3 3/8 Dia) axles.
03-11-2004 18:24:06
 Re: Re: Re: Whtie 2-180 Hubs in reply to Dean Barker, 03-10-2004 20:57:12
Hi, Dean! Thanks for the info. The newer Whites I sold and worked on all had the larger axles. I wasn't aware of a smaller diameter axle shaft. When the Workhorse series came out, I thought that White had a near-perfect machine. Too bad that they are no longer made. I guess it makes the ones that are out there even more valuable! They are one incredibly rugged, durable and simple machine.
Merlin
Dean Barker
03-11-2004 22:09:36
 Re: Re: Re: Re: Whtie 2-180 Hubs in reply to Merlin in Saint Louis, 03-11-2004 18:24:06
I agree. One of the best tractors, ever. FYI, a kit was released for 3 7/8 axle tractors above 200 HP except articulated tractors that increased axle dia to 4 5/16. I assume that it is still available. It wasn't really needed unless the tractor was weighted to around 30,000 lbs.
