550 3-pt.
Tom
03-08-2004 09:27:23
See many posts on cycling of 3-pt. hitch.
Where should the adjustable bolt on the top link mount be set? It goes up against the seat mount.
I have a later model 550 with the fiberglass front end. Does it have both position control and draft control? Can this function be disabled?
Larry from MD
03-08-2004 16:23:23
 Re: 550 3-pt. in reply to Tom, 03-08-2004 09:27:23
You don't have the shift lever like the older tractors.The ajuster bolt does the change.When the bolt is backed off so the mount will pivot against the spring you are in draft + position control.tighten the bolt so it wont move and you are in position control only.
