Oliver Super 88 Water Pump Seal
Ross
03-07-2004 21:06:07
Hello, Is there a seal available to replace the seal on the waterpump of a 1956 Super 88 Gas tractor? It is sort of a strange spring loaded rubber seal. Thank You, Ross Boots
J. Schwiebert
03-08-2004 03:11:36
 Re: Oliver Super 88 Water Pump Seal in reply to Ross, 03-07-2004 21:06:07
The seal is still available as it fits many different water pumps. However the part number for the part changed many years ago. The last I knew the part number was 159 051A but that may have changed however I picked up a spare to stock last spring with that part number.
RAB
03-07-2004 23:05:53
If it is same design as later 90 pumps, then it is easy to make your own from a suitable electric motor brush and elctrical cable glands. I did mine 15 years ago, or so and it is still OK.
Hope this helps.
Regards, RAB
