hard starting 1949 77 row crop
mike zimmerman
03-07-2004 07:26:15
i have a 1949 oliver row crop 77 that does not like to start. it cranks over very,very hard but if you choke it once gas get into engine it seems to crank over nomal until it starts.i was woundering if there is anything i could try besides changing it over to 12 volts because i am trying to keep it ALL original. it just does not seem to have enough juice to crank over the engine like it vapor locks.jump starting seems to help but any suggestions!
mike
03-15-2004 10:43:48
 Re: hard starting 1949 77 row crop in reply to mike zimmerman, 03-07-2004 07:26:15
ok here is the latest i finally got to work on it
i tested the bat. before and while cranking
before was around 6.4
while was around 4.5
at starter was alittle lower
so i went and got all new cables (start button replaced not long ago)and also found pos. cable got hot while cranking so when i put the cables on i ran an extra one from where the pos. bolts to the batt. box over to the starter mounting bolt
then tested again
before was same
but while was 5 to like 5.5 and same at starter
it cranks alot better but still seems to have trouble like starter has a hard spot
if you play with the start button it you can get it to crank prettygood
so what do u think everything seems pretty good up to the starter and i had that checked but i dont think it is right any suggestions to try without buying a 200$ starter ( thanks)
J. Schwiebert
03-07-2004 12:39:37
How good is your starter and the starter circuit? Those old push button starter switches tend to wear. Do you have a good voltmeter. If you do place it across the battery and see what voltage you have as you try to start it. Then place it on the starter and take a reading as you crank the engine over, This may require a helper depending on what kind of terminals you have on your volt meter, see how much voltage drop you have and then get back with us.
