Super 55 Fuel Line
Biscuit
03-05-2004 16:56:36
Hello All,
It is finally spring time here in New England...well maybe. I have the carb for my Super 55 at the shop being rebuilt and figured I'd modify the fuel line before putting the "new" carb back on. I am interested in putting an in line filter in the gas line. I have seen several posts on here about doing this modification. I saw a post that mentioned needing to add a low pressure fuel pump because after adding the filter there wasn't adequate fuel flow. Is this common with the addition of a fuel filter? If so can anyone tell me a good brand or part number for an adequate fuel pump with the original 6V + ground system. What size is the fuel line on the S55? Mine is copper tubing with flare type connectors. Wondering what you all use for fuel lines.
Thanks all,
Biscuit
ron
03-07-2004 13:23:16
 Re: Super 55 Fuel Line in reply to Biscuit, 03-05-2004 16:56:36
i have 2 770's that have this inline filter. one is in a rubber line, the other one somebody cut the steel line and inserted filter and 2 short rubber lines with clamps. both ways seem to filter well, and the tractors don't starve from lack of flow. i wonder who told you yours would? try it out. you will be ok. good luck ron
Stu
03-06-2004 12:56:21
I have the exact simple system as you refer to. Out of the tank is a rubber fuel line into and inline fuel filter(3$), and and then runs down a rubber fuel line around the battery box and into the carb. No fuel pump, no problems.
