S88 HYDRAULICS
WC
04-26-1998 10:34:02
the hydraulic system on my 1955 super 88 seems to lack the pressure to lift my 3 bottom plow. it will lift it, but the throttle has to be wide open and then it comes up very slow. it is a pain
to plow when you have wait for the plow to come out of the ground ! is there an adjustment
or does it need overhauled?
larry H
04-26-1998 13:27:32
 Re: S88 HYDRAULICS in reply to WC, 04-26-1998 10:34:02
it sounds as if one or more of the orings under the unit are blown or the filter is plugged it can be turned up by adding washers to the relief valve
: the hydraulic system on my 1955 super 88 seems to lack the pressure to lift my 3 bottom plow. it will lift it, but the throttle has to be wide open and then it comes up very slow. it is a pain
: to plow when you have wait for the plow to : come out of the ground ! is there an adjustment
: or does it need overhauled?
