Hydraulic leak
bob strawn
06-01-1999 23:23:00
Hi Folks! I recently bought a 1960 880D Oliver tractor. After sitting all winter it seems all my hydraulic fluid has drained into the trans. Anyone know what is the cause of this. Appreciate any help.
Bill
06-02-1999 19:27:56
 Re: hydraulic leak in reply to bob strawn, 06-01-1999 23:23:00
Some water may have collected in the pump and pushed out the seals. You may need to replace the seals. Have a mechanic check the pump while it is apart because they sometimes need bearings and/or resurfacing at the same time. This will require taking the unit off the tractor.
bob strawn
06-06-1999 12:32:40
 Re: Re: hydraulic leak in reply to Bill, 06-02-1999 19:27:56
Thanks Bill! I suspected as much!
Eric Bloom
06-07-1999 03:02:47
 Re: Re: Re: hydraulic leak in reply to bob strawn, 06-06-1999 12:32:40
Whenever you have the pump out. don't get the seals or bearings from your ag dealer. Go to your local bearing supply house. The seals especially. The seals they have are twice as good and half the cost of the AGCO replacements. you would just need to take the old seal in and have them measure it up. I think i may have the numbers of the seals and bearings wrote down. I will look and see.
bob strawn
06-10-1999 11:47:21
 Re: Re: Re: Re: hydraulic leak in reply to Eric Bloom, 06-07-1999 03:02:47
Thanks Eric! The numbers would help a lot if you can find them.
