Sputtering Oliver
Paul A
06-01-1999 19:18:29
I'm new to this board, I guess because my Oliver 550 has run flawlessly for several years. This Spring I replaced the in-line fuel filter. And now it ain't running so good. Idles fine, but sputters out after revving it up for awhile. Like it's running out of gas. I took the carb off, cleaned out jets and found a hunk of tubing rubber in the adjusting jet on the bottom of float bowl. Replaced fuel hose, cleaned the carb up and put it back on, but it still does the same thing. Is there a high end jet I missed? Or something completely different?
Tom
06-04-1999 19:43:20
 Re: Sputtering Oliver in reply to Paul A, 06-01-1999 19:18:29
Paul I would check the fuel comming from the tank also.Could be plugged and only letting 1/4 of the flow through.Enough to start and run for a little while but not enough to go anywhere.Just worked on a 1800 gas doing the same thing had bugs and leaves plugging tank exit.Run for ten minutes than shut off.Good luck:}
Dennis(WA)
06-07-1999 14:41:15
 Re: Re: Sputtering Oliver in reply to Tom, 06-04-1999 19:43:20
Paul, I agree with Tom. If you found junk in your carb, you have junk in your tank. Get your trusty flashlight and see what you can find in the tank. You might want to rebuild your carb if cleaning out the tank doesn't fix it.
