Super 88 for pulling tractor value
john james
05-31-1999 19:05:40
I have been looking for a pulling tractor for my two sons, ages 9 & 6. We want to pull in some antique pulls, however the tractor will at the minimum have to earn its keep by pulling a N.H. Super 66 Baler. Any one have opinions on the use of a Super 88 for pulling. Secondly, I found one for $1,600.00. The metal is clean, needs painted. I could not find any fluid leaks and it seems to run very well, shifts good, electric system works. Is this a reasonable value.
Twin '55 Super 88s
06-01-1999 04:37:55
 Re: Super 88 for pulling tractor value in reply to john james, 05-31-1999 19:05:40
I gave 1850 for one that fits your description, a very tight tractor. One thing that may get overlooked is hydraulics and condition of steering system. The only way to check hyd system is a presure gauge or try to lift say, a 3 bottom plow or 8 or 10 ft disc. The steering may wobble at high ground speed even if it seems tight at a standstill..
john
06-01-1999 09:27:22
 Re: Re: Super 88 for pulling tractor value in reply to Twin '55 Super 88s, 06-01-1999 04:37:55
thanks for the info. Have you pulled with your 88 as yet. If so, how have you done. The one concern I do have on this tractor is a hole in the exhaust manifold. Looks like it can be patched. I saw new ones available as well. I don't think this should be a major item. Let me know if you think otherwise. I appreciate your help. We've always used Allis tractors for farming, however, the old ones just aren't geared for pulling very well
Twin S-88s
06-02-1999 10:37:41
 Re: Re: Re: Super 88 for pulling tractor value in reply to john, 06-01-1999 09:27:22
Like you I am just getting into pulling. I pulled for the first time last year and that did not go without learning something. I was beat out by a couple of Farmall M's. The weight I added needed to be farther forward to help keep the front down. The M's were loaded right on the front of the tractor. I had plenty of power, just lack of traction. Since then I read that if you are going to pull 88's seriously, the calcium needs to be drained, and replace the rear cast wheel with a pressed steel rim. This allows you to pull in a lighter class and just add weights for the heavier classes. Try J-B weld on your manifold. I had pits around the exaust ports that new gaskets would not seal, filled them with J-B weld and filed them of, and they held ever since. I have seen some WD 45's pull pretty competetivly, but it was obviuos they were a little reengineered and pulled a class lighter than 88's would pull.
Eric
06-05-1999 05:30:46
 Re: Re: Re: Re: Super 88 for pulling tractor value in reply to Twin S-88s, 06-02-1999 10:37:41
I pull a 77 but also have pulled some 88's. if it is going to be a puller then you definetly need to get rid of the cast wheels and fluid. Pressed steel will save you about 1200lbs(per tire) over a cast one with fluid. I have pulled a stripped down 88 at 3800 lbs. that is about as light as you can get. An 88 will really pull better in the 4500 and up.
