OH no wifes mad now !
So. IL. Farmer
02-28-2004 17:38:10
Just got back from an estate auction with my first Oliver, a Super 88.The tractor hasnt run in about 10 years.Motors stuck now,but was using lots of oil when it was running way back then.Needs overhaul,new grill,tires,one rear wheel.Sheet metal isnt to bad,just needs some work.I got the tractor with side shields and front mount cultivator for 325.00.Saved it from death at junk yard.My question is what model are the cultivators? No tag on them just a well worn Oliver decal.Also there was a front mount 2 row corn planter too no,but bad shape to buy.Does anybody know anything about the implements.i will try to post some before pictures. Thanks Alot.
Larry NE IL
03-01-2004 19:59:04
 Re: OH no wifes mad now ! in reply to So. IL. Farmer, 02-28-2004 17:38:10
Wives have a way of doing that every now and then. Just play ostrich for a while, you know, stick your head in the sand and wait for it to blow over. G'Luck Larry
Roger
02-29-2004 19:02:22
Hope yawls wife is not like mine, she's had that old dreaded mad wife disease for years.
Brad A
02-29-2004 07:10:11
Think your wife is mad?
I got mine a new set of 18.4x34's for Valantine's day. Even though they are for her tractor, I'm not real sure it was a good idea. So you can tell your wife that its not so bad that you brought home a tractor, other wives have it much worse than she does. Its all in the perseption.
RUSS
02-29-2004 05:38:43
Oliver 88; So sorry to hear your wife is MAD
(first time, still, right now, again, what's new).
I think the 88 will dress up real nice. Would be
good to see a few before and after pix as the rebuild moves forward. Good luck with the project and the mood of your better half. You have chosen a good tractor to rebuild.
Super 55
02-28-2004 21:02:56
Why is the wife mad? Was she bidding against you? Sounds like you got a fair price on that tractor.
luther
02-28-2004 21:00:12
Jeez, 325 bucks! Sounds like a steel too me! Possibilities are endless!
W Ky puller
02-28-2004 20:26:10
If the wife gets to hot drop me a line I've been looking for a 88.
oliver farmer
02-29-2004 02:09:31
 Re: Re: OH no wifes mad now ! in reply to W Ky puller, 02-28-2004 20:26:10
if your cultivator is a pipe mount, it probably is a 1095 or a 1096. is it a hydrolic lift or a trip lift?
