S55 Help
Mike
02-24-2004 18:25:04
Hello,
Has anyone sucessfully been able to remove the front axle pivot pin on a Super 55? I have tried heat, a slide hammer screwed into the threaded hole in the pin as well as using a section of pipe with a piece of all thread as a puller with no luck. Any suggestions would be appreciated. PS I did remove the set screw from the bottom side.
Thanks,
Mike
Super 55, more info
02-24-2004 22:26:52
 Re: S55 Help in reply to Mike, 02-24-2004 18:25:04
I checked the archives. There was a post that said that Chris Losey at the Old Oliver Gang web page had done it and could tell you. When you get there go to forums, Oliver, then post.
Super 55
02-24-2004 19:10:12
Ah, the pivot pin dilema. This has been on before, but I can't remember the best method. Try doing an archive search, because it has been discussed more that once. You are not the first to be frustrated with that pin.
Keith
02-26-2004 07:26:07
 Re: Re: S55 Help in reply to Super 55, 02-24-2004 19:10:12
I got one out by using heat and air impact. A rosebud will get it hot enough.
