E3 Coop/Cockshutt 30 hydraulic valve
Scott Thomas
02-19-2004 17:07:45
I have 2 hyd. valves for a E3 Coop that don't work, I don't think they work? They are both off the tractor, one is stuck, and the other one, I put air in the rear port on the top and air comes out the other three. It is rectangle with two ports on the top and two on the bottom, is there a replacement that be bought or someone that can rebuild them, maybe sell one and keep one. They were off the tractor when I bought it 4 weeks ago.
P Heisey-Harleysville,PA
02-20-2004 03:24:19
 Re: E3 Coop/Cockshutt 30 hydraulic valve in reply to Scott Thomas, 02-19-2004 17:07:45
Scott,
I have used hydraulic valve body controls and some new and used valve assy. parts for your front pump mounted control valve on your Cockshutt 30 Tractor.
Phil Heisey 215-256-8651 eve. FAX 215-256-1203
