Cletrac OC-3-42N parts???
old
02-19-2004 14:20:40
Other then Zimmermans is there any other places to find parts, I'm going to be getting an OC-3 soon and would like as many opyions for parts as I can find, mostly engine parts since it has a spare engine. Also will an engine from an OC-3 fit/bolt up in an HG, or is it the same or bigger??
Any help would be nice please.
550man
02-20-2004 04:45:33
 Re: Cletrac OC-3-42N parts??? in reply to old, 02-19-2004 14:20:40
An oc-3 engine will fit in an hg, the bellhousing might be a bit wider on an oc-3 but everthing will fit around. the only thing that is different is the Hercules IXB-3 (oc-3) engine has a bore size of 3-1/4" and the Hercules IXK-3 engine (HG) has a 3-1/8" bore size. Some of the later HG's had the IXB-3 engine too.
make sure you don't get an Hercules IXB-5 engine as these were used in alot power units and will not fit in an Oliver crawler.
DICK TRACY
02-19-2004 18:10:08
[email protected] got some from he for less then Zimmermans
