found all filters but 1..........
riverrat
02-19-2004 13:40:48
Model 1650 backhoe (Parsons)- I found all the filters (rear end, primary and secondary fuel, engine, and reverser) but where is the hydraulic filter? Seems it would be a big one and hard to miss, but darned if I can't find it! Please help, thank you!
Sam M
02-19-2004 15:01:17
 Re: found all filters but 1.......... in reply to riverrat, 02-19-2004 13:40:48
On the standard 1650 farm tractor , the hydraulic filter is located in a bell shaped housing that sits just in front of and below the driver's seat between the driver seat and the gear shift lever . The front of this bell shaped area is shaped like a nut ( 1 1/4 inch to 1 1/2 inch appoximately in size ) . YOu loosen , unscrew and take this bell shaped housing off and the hydraulic filter element is inside . However you have a backhoe so it may be different than the standard farm tractor .
riverrat
02-20-2004 16:01:25
 Re: Re: found all filters but 1.......... in reply to Sam M , 02-19-2004 15:01:17
Thanks for anwering, Sam M. Still can't find it, though. Need to crawl around under it with my light as soon as I have some time this weekend. Thanks again for replying!
